Keep blowing up radiators
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
Hi I’d like to thank you in advance for taking the time to help me with this. I have a ZD326 zero turn that is my baby. It has just over 640hr it’s a 2011 and it gets a full service and cleaning after every use. So lack of maintenance is not an issue. I had an overheating issue about a year ago so I replaced the radiator with a good flush of the system. It’s been working great tell a couple of weeks ago when it sounded the overheating alarm and I pulled under a tree. I shut it off as the radiator blew up. Split the top open. As soon as the alarm went off I looked at the gage it was just about in the red maybe an 1/8 from it. Now the radiator was not clogged. The thermostat has been out of it for a while. I’m in fl no need for one here. I replaced the radiator with a new one. New cap with the recommended coolant. Ran the mower for about 10 minutes to check for any pressure buildup. Found nothing to suggest a head gasket. Started mowing and around the 10 minute mark I looked at the gage it was just about to the red and before I could park it the alarm sounded and the radiator split the top wide open again. I’m at a loss need help finding the problem and a fix.
Caden
1979 B7100
Apr 16, 2026
80
Do you think the water pump is working as it should?
Also maybe monitor the gauge more often so you could have avoided the second explosion.
john_circumnent
Kubota
Apr 29, 2026
First thing I'd do is stop running it until you figure out why it's making that kind of pressure. A hot engine alone usually will not split two radiators that fast. You need to test for combustion gases in the coolant with a block tester kit; a leaking head gasket or cracked head will pump pressure in long before it actually hits the red. Also make sure you have the correct pressure cap, not a higher PSI one.
Next, with the engine cold, cap off, start it and watch for a violent surge in the neck when you crack the throttle. Gentle circulation is normal, big bursts point to cylinder pressure. Also confirm the fan is pulling air through the radiator and the belt is tight. Did it ever overheat badly before that first radiator?
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
Yes you’re right I needed to look at the time more. But it was in the middle of the gage about 5 minutes into it so I let myself get lost in mowing the outer edge around the fence and before I knew it it was overheated. That’s my fault on that for sure. The water pump I think is working. It was moving the water good when I was letting it run the first time checking everything after the radiator changed.
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
No not after I replaced the first radiator about a year or more ago.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,390
589
Richmond, Virginia
Hot fluid should blow out the overflow of the cap, sudden excessive pressure tells me you have a head gasket or a cracked head issue. You can get 'combustion test strips' from an auto parts store to verify combustion gases are present.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
454
529
NE Ohio
What about the radiator cap? It should've released the excessive pressure before the rad blew.
#40Fan
528
375
Thermostats not only allow the engine to run at a certain temp, they slow the flow of coolant so it has time to dissipate the heat through the radiator. But, I suspect that isn't the main issue here.
William1
Jul 28, 2015
1,390
589
Richmond, Virginia
Not if the volume and pressure is suddenly more than the cap can vent. An engine simply over heating slowly rises in pressure and once exceeding the cap design, starts to bleed off. A sudden sharp increase may well of exceeded the caps ability. Imagine a full cylinders pressure suddenly being dumped into the coolant.
JimDeL
Aug 31, 2022
454
529
NE Ohio
With a full compression pressure into the cooling system I'd expect to have a hose blow before the radiator.
The OP said he'd parked the tractor before the rad blew. If that was the case what would cause the problem? I dunno.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,176
2,818
Near Lancaster, PA, USA
First - I'm not a mechanic or an engineer
Can the lack of a thermostat be causing the overheating? Doesn't the coolant need some dwell time in the radiator to have some heat extracted?
Is the engine heating and boiling the coolant to the point it flashes to steam? If that happens the steam created instantly occupies 1700X the volume that the water did. No cap that would be capable of venting that.
6,896
The answer is no.
With some subtle caveates the RATE of heat exchange is the same with or without a thermostat. Without the thermostat an engine runs colder because the coolant circulates faster. Thats more volume per unit time which means it absorbes and exchanges more heat per unit time.
The "dwell time" idea is bogus physics.
Hugo Habicht
G1900
Jun 24, 2024
1,495
2,150
Ireland
..... The thermostat has been out of it for a while. I’m in fl no need for one here. ...
Removing the thermostat may not be a good idea. Depending on the design the thermostat opens the radiator loop and simultaneously closes the small loop, which only circulates the water without cooling (not to dead head the pump). By removing the thermostat you will have an undefined flow, mainly through the small loop, significanly reducing cooling capabilities of your system.
Also the thermostat regulates your engine temperature. Removing it has your engine running at an uncontrolled and unknown temperature.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,711
2,285
WestTn/NoMs
Hokie and Hugo are correct. There is also the possibility that removing the thermostat removes so much resistance to flow that the pump cavitates. In any case, I'd test it and reinstall.
I don't know how this ZD is laid out, but there are more cars where there is an air pocket in the heads that won't fill normally. I had an '89 Cherokee 4.0 that had to go through several heat-cool cycles to work it out (I didn't know about the vacuum pump method). So I'd let it cool off and check coolant frequently after draining it.
The other possibility is water pump failure. It's not unheard of for the impeller to come loose and spin on the shaft.
6,896
Heres anorher interesting one. Some early stock car racers removed thermostats to reduce parasitic load and increase cooling. Oddly some wound up with overheating failures. Without the restriction of the thermostat the high RPM operation increased flow force so much it pushed coolant past the pressure cap on the radiator. The engine would pump itself "dry" and overheat.
Thers a lot going on in a modern cooling system and removing the thermostst is a bad idea.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,711
2,285
WestTn/NoMs
Heres anorher interesting one. Some early stock car racers removed thermostats to reduce parasitic load and increase cooling. Oddly some wound up with overheating failures. Without the restrictiin of the thermostat the high RPM operation increased flow force so much it pushed coolant past the pressure cap. The engine would pump itself "dry" and overheat.
Yep, so these came about
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
Shane37
Zd326,Rtv900,L3200
May 4, 2026
Florida
You might say they were the first generation of NASCAR restrictor plates 😊
Thanks for all the advice. It was a blown head gasket. I like all the debates this started on the thermostat. Iv been in auto racing for over 20 years now from quarter midgets ,legions, Late Models and Stock Cars in NASCAR. If I ever told one of my engin builders I had a thermostat in one of there engines I’d probably no I know I’d get the biggest wrench thrown at me.
