Kabota B2410
Bikeman Vincent
Kubota B2410
Jul 30, 2021
Lake Elsinore
I have a kabota B2410 With HST. I was using the tractor digging a hole with the bucket and all of a sudden the tractor dies. There is no power on the instrument panel, I checked the big 30 amp fuse on or near the starter to find that it blew out I replaced the fuse and it blew out. So I figure it is a short somewhere within the system I proceed to take off the Cover over and around the instrument panel to discover rats had been inside and thought that that would be the problem but could not find any indication that there was any wires chewed or Burned. Now I have no fuse in it and I attempted to jump it from the starter which it started up but would not stay running I used it enough to raise the bucket up so it stayed started for a little while But would die I have done this for or 5 times which every time it started but wbut would not stay running also also still no electrical electrical on the dashboard. Don't know what to do next.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Find where the short is! Something is worn through in the wiring from the starter into the dash
