Hey guys,
I'm new here and looking for some help diagnosing an issue with my 2014 Jacobsen AR3 mower and has a kubota D1105. The mower starts up and runs perfectly with the fuel shut off solenoid removed. I've eliminated it being any safety switches, replaced all the fuses, relays, replaced ignition switch and bench tested the solenoid to make sure it was working correctly. I've tested the plug going to the solenoid and it gets voltage when trying to start but all voltage drops off as soon as the key is returned to the run position so it seem that I'm not getting any power to hold the solenoid open. I know this isnt a tractor but thought this would be a good place to look for help since this mower has a kubota and any help will be greatly appreciated.
Thanks
Drew
Thanks
Drew
