ITC brand toolbox kit for tractors ?
Trustable
l2501HST
Jul 5, 2022
397
411
Looks very nice for an all in one solution, I am not sure about the price though, seems a bit high IMO.
GrumpyFarmer
5,221
Looks pretty nice, not free, but looks really well designed and clean cut. Some of their other items look well thought out too…thanks for posting link.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,385
1,007
Minnesota
There is a thread on using an ammo can mounted to your ROPS. Allot cheaper. Just search and you will find it.
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
40
31
Missouri
For me, mounting on the rops would make it less accessible. I'm typically off the tractor when I need tools so for me something lower would be better.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
723
841
NE FL
Metal ammo cans make nice tool and chain storage. Walmart has some decent metal cans for cheap but I recently found Academy Sports carries some heavier ones for around $30. I usually mount them by drilling into where I want them and installing 5/16" rivet nuts and spacing the box out with 3/4" plywood. I drill a couple of offset holes in the sides of the box and bolt them on with fender washers under the bolt heads.
5,481
I will add that I originally used a “Chi-Com” ammo can for my tool box.
In short order, the bouncing from the machine, along with improperly sized and placed bolts, the bottom ripped apart.
Luckily I saw it and removed it before it could fall off and scratch/dent the tractor.
I would/will add a “bottom backing plate” if/when I replace the can. (or possibly find a better/thicker one 🤷‍♂️ )
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
It's difficult for me to find a suitable place to bolt a box on the tractor. My approach is a $10 HF tool bag. It has various small tools, pins, etc for quickie fixes. On the Kubota the bag and a roll of paper towels sit between the seat and the rear wall of the cab. I don't carry anything on the Ford.
The farthest I go when leaving the property is about two miles. If anything serious is needed it isn't a long trip back to the garage for what is needed.
Farm Fun
May 4, 2026
40
31
Missouri
The pricing doesn't sound too bad at first. But then it's another $100 for the standard loader mounting bracket.
Farm Fun
May 4, 2026
40
31
Missouri
After a lot of consideration and research, I went with the ITC toolbox system. Again, not cheap but it adds much needed storage and cost is a small part of the tractor purchase cost. Got the version that attaches to the loader. All the metal is well made. Had to watch a video on it as there weren't any written instructions; was then simple to understand. My only negatives are I'm not too sure how the plastic tool box will hold up over time and that I wish the system offered the option of using different size/design tool boxes.
