ISO Lower Link arms for L-series tractor
H20man53
L35 tractor w/ loader, 5' tiller, 6' blade
Oct 8, 2022
Neoga, Illinois
Looking for lower link arms about 26" in length that would fit a Kubota L35. Also looking for the fixed drawbar.
5,131
The parts you are looking for (for L35), are going to be VERY difficult to find as used parts.
I believe that those pieces may still be available new, but are likely VERY spendy.
H20man53
Oct 8, 2022
Neoga, Illinois
Currently I have lower link arms from a Ford tractor which are too long and no holes for the stabilizer chains. A pain to change implements since the sway chains use the same pins and have to be removed.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,101
1,701
WestTn/NoMs
Unless you find some good used ones (or the missing stash of misplaced ones :)), I think you'll do better to buy the L3961 kit from your dealer. It's around $600 now.
If you search this forum by 'L3961' and my name, you should find some pictures I posted with dimensions.
H20man53
Oct 8, 2022
Neoga, Illinois
Thanks for info on L3961 3 point hitch used on the L35. Have you installed the kit on your L35 yet? I would like to know how it works out.
5,131
Coleman Equipment has the L3961 3pt. hitch kit listed on their website for $594.72...... plus shipping.
A call to Coleman would seem to be in order to be certain that is the proper 3pt. kit for your L35
No readily available info for a Kubota OEM L35 drawbar.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,101
1,701
WestTn/NoMs
No, I haven't. I don't think the backhoe has ever been off.
If I can, and remember (CRS setting in), I'll see if the lower arms fit. I think I can do it without removing the hoe. May be Monday.
BTW, you should be able to save shipping if you get it on your dealer's shop order. Worth considering.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,101
1,701
WestTn/NoMs
I tried my L3961 parts. The lower arms I couldn't install to the rear because of interference with the backhoe. But I put them pointing to the front - the eye is the correct size and length for the pin.
The lift rods also match the size and length of the lift arm pins. The angle of the stirrup appears to match the angle of the lower arms when lying on the floor.
I didn't measure the length again, but you can see it in my earlier post.
