Iseki tx1410
Clive
Ireland
Hi everybody ,hopefully some can help me with a couple of questions ,1 greasing front axle no matter how much grease is pumped in it dose not show ,how do I no when there is enofe grease in
2 when I stop the tractor and dip the rear end oil pumps out of dip stick hole why is this
Help would be appreciated ,thanks again
Tooljunkie
May 13, 2014
4,150
34
It would help to know what you are greasing. Im guessing at the axle ends. As in king pins/ball joints. They are open to inside of axle housing with some sort of seal. 4-6 pumps would be enough to lubricate knuckle pivots. By greasing too much-likely have pushed grease into axle housing. Likely popped seal. Photis would help. Iseki isnt kubota, i cant even direct you to a proper forum.
Clive
Ireland
Hi and thanks yes it is the king pin ,so do you think I have done any harm or what should I do ,I put about 15 pumps of grease into it ,
Tooljunkie
May 13, 2014
4,150
34
Its Blue!
I guess im in trouble now....
Wouldnt know if any harm is done unless there is a parts diagram/workshop manual we could refer to, to see if there is a seal in there. Why oil is coming out is beyond me, unless it was right full before greasing. Grease woukd have displaced oil. I wouldnt worry about it.
Clive
Ireland
No trouble ,it's blue alright good kubotsa are hard got here in Ireland ,so I had to go blue ,
Has any body got a idea why oil wiil push out of transmission dip,stick hole when the tractor is stoped
Clive
Ireland
I dipped it a week ago and the level indicated the the oil level was spot on ,and I dipped the other day and oil started to pump out slowly ,
Treckerzeug
Carraro tgf 7800 taijfun 4,5 t winch, trailer with crane, double bl saw
Apr 17, 2015
135
19
Bavaria South Germany
Hi,
To grease the front axle the most important thing to do before is to lift it with a jack, to releave pressure from the moving parts, only by doing so you get the grease in all places where it is needed.
Regards
Robert
