Is 1000lbs to much
mikes1165
L3901DT, LA525FL, King Kutter 6' finishing mower, 5' Bush Hog Squealer,Box blade
Jul 30, 2015
107
Mulga
I'm building me a ballast barrel for my L3901 with L525 FEL. I was going to make it 1000 lbs but I wonder if that is to heavy for my tractor. The 3 pt hitch lifting capacity is 1985lbs but says the max weight for a rotory cutter for example is 770lbs. The max for any implement it list is 926lbs for the backhoe but says a subframe is necessary. The loader capacity is 1000lbs. My thought was that 1000 lbs between the lift arms wouldn't be any more strain on them than 770lbs hanging 6ft behind them. Would 1000lbs be to much or be about right?
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
461
61
Red Springs, NC
You will be fine. I have 12 100lbs tractor weights on a homemade 3pt bar that I use on the rear of my L3700SU when loading dirt it the backhoe is not on. This will also reduce wear on the front axle since you are adding counter weight behind the rear axle. Water in the tires is just that, it will help hold the rear tires on the ground but will not offer any counter weight.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,055
Williamstown Ontario Canada
If using concrete, it weights 150# per cubic foot so you will need between 6 & 7 cu ft.
Low and wide is my suggestion, not tall. You dont want it unstable when sitting not on the tractor.
Dave M7040
mikes1165
Jul 30, 2015
107
Mulga
I figured if I put approx 400lbs of scrap steel in it then I can only fill barrel 2/3 full of cement and have 1000#. That keeps the weight low and I'll have 12 inches in the top of the barrel to carry chains, tools etc.
bmblank
Mar 4, 2015
771
488
Cadillac, MI
Remember to allow for water to drain easily. It'd be a shame to have tools and chains in there sitting in a couple inches of water.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,055
I would embed the scrap steel in the concrete and then if the bottom of the barrel rusts out the steel will still be there.
Dave M7040
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I would fill the rears with fluid just for the added traction, the weight will be a bonus. Then a 500# or so counter weight should be enough.
Deaner70
L3301, LA525 loader with QA, LAnd Pride RCR1860 hog
Aug 26, 2015
53
Shreve, OH
Wondered the same for my 3301. Moving bales gets a little nerve racking. Added WW Fluid to the rears. Was told its 200# per side. Made a difference but still need more, Anyone ever price a Kubota ballast box? afraid to ask
