I Put A Kink In My Bucket Hitch
MTBob
2018 L6060 HSTC Kubota, Land Pride blade RB3785
Aug 10, 2019
Belgrade, Montana
Commercial bucket hitchs have a design flaw. The piece that mounts on a bucket positions the extension arm and ball parallel to the bottom of the bucket. So, when the hitch arm is horizontal, it is impossible to see the ball from the operators seat due to the top of the bucket blocking view of the hitch ball, unless the arm extension is extremely long. So I designed a bucket hitch assembly that positions the arm extension parallel to the ground when the bucket is fully rotated upward, adding a "kink" to the hitch angle.
With this design I can now see the ball from the operators seat.
One fatal flaw that many commercial bucket hitch connectors have is their inability to handle lateral loads, and they rely on friction for pulling. I added a clip bar that fits behind the bucket cutting blade to solve both of these issues. This hitch will now easily pull my 17 ft Lund Boat and handle a sharp right or left turn.
The hitch connector uses a simple drop pin to hold the arm extension. I've added horizontal pin holes to fit standard hitch inserts, if ever needed. I have another arm that has a pin head instead of a ball to move a hay wagon.
Reactions: 6 users
6,383
When I had a B8200 I drilled a hole and mounted a ball on the top of the loader bucket. I could easily see the ball and roll the bucket forward to get it under the trailer hitch. Then roll the bucket back level to use it.
radas
Mar 21, 2022
719
833
Looks good! Do you notice any deflection where the hitch meets the bucket or further out where the ball is mounted? Looks very solid.
5,131
Like you, I have the hitch coupler mounted at the top of my bucket.
My bucket is too tall though, to roll it enough to see the ball actually engage the trailer coupler.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,024
843
canada
Excellent, very well though out. Sometimes a guy needs to build his own to get what he wants.
MTBob
Aug 10, 2019
Belgrade, Montana
So far I don't see any noticable deflection. The extension is 2" tube, .125" wall. I opted for a slightly less thick wall than standard hitch tube.
