I have a BX2200 with two leaking hydralic hoses on my loader la211
Wade Williams
Kubota B2200 with LA211 loader
Sep 5, 2021
Wisconsin
it looks like I need to remove the Husco valve to get access to two of the fittings, any advice on removale and re assembly ? Thank you.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,254
1,037
Williamstown Ontario Canada
Be very careful to mark which hose goes where on the valve. Frequently owners post about strange hydraulic behavior after removing and re-installing a hose or two. Cause is always a hose put where it does not belong.
Dave
5,417
2,108
yes welcome to bx's
that valve. everything imaginable is packed into a small space. Like putting 10 lbs of taters in a 5 lb toe sack.
no fun to work on!
Mark everything well. Use your phone to take plenty of pictures so u know how it goes back together.
the most common leak points on the bx2200 was the power steering hoses I bet I did 250 of them! They rub and then they leak. I put sleeves on them but because of the design it only prolonged recurring leaks.
