hydraulic top link , and rear remotes for a grapple
dcflyer
jamestown
new to hydraulic designs ; what am i in need of to install a hydraulic top link for a grapple on my l2050 tractor. just starting that learning curve
8,592
Normally a rear remote does not run the grapple, it's normally a third function setup on the loader to run the grapple and rear remotes to run top and tilt.
Yes you can use a rear remote to do it, it just requires a lot of hose to pull it off.
dcflyer
jamestown
my tractor is not set up with a front end loader hydraulic system , working to get hydraulics front and back , front loader is the la480 type . there is one coming up on auction , before i purchase a front bucket system , i am trying to learn what is required , so i know more to make an informed purchase, any insight will be greatly appreciated
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
there are a few 3 point rear grapples
or you want a 3rd function kit to add to a front end loader.
8,592
Little confused by what your saying and how your saying it.
Please clarify:
Do you already own the tractor?
If you already own the tractor are you trying to buy the FEL (Front End Loader) and install it on your tractor?
Or are you thinking of buying the tractor then wanting to put the loader on it after you buy it?
If you already own the L2050, is it a DT (4wd) with power steering?
Also your going to have a tough time getting a LA480 to fit on a L2050, it was designed for a larger tractor with different mounting ability.
And if you do get it to fit, it might be slow and weak as the Hydraulic output of L2050 is only 4.4GPM where the L2900 is 7GPM.
Lets keep everything on this thread to get to the bottom of this for you. ;)
