J jerry15 New member Equipment B2150 HST Dec 7, 2010 4 0 0 Covington, Ky Sep 17, 2018 #1 My hydraulic system just all of a sudden started bleeding off and after I move handle back to raise my belly mower it will come back down very quickly. Is there a simple repair? Diaphragm or valve need to be replaced.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,500 8,770 113 Sandpoint, ID Sep 17, 2018 #2 Most likely if it was a sudden onset then it has a failed piston seal, or fluid level is low and it's pumping air into the system.
J jerry15 New member Equipment B2150 HST Dec 7, 2010 4 0 0 Covington, Ky Sep 18, 2018 #3 Piston seal hard to replace? Plenty of oil
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,500 8,770 113 Sandpoint, ID Sep 18, 2018 #4 jerry15 said: Piston seal hard to replace? Plenty of oil Click to expand... I wouldn't say so, but i work on these all the time.
