Hydraulic pressure adjustment
wiltff
L3800 HST & FEL. 66" LP Tiller, 72" EA Boxblade, 84" Woods disc, 96" rake
Aug 6, 2016
Milwaukee, WI
2014 L3800HST. I just checked the hydraulic pressure on my FEL and it was 2200psi @ 2000 RPMs and 2250 @ 2500 RPMs.
I have looked through past posts and cannot seem to find the post on how to increase the pressure with the washer and I vaguely remember an article about a vacuum to not lose any hydraulic fluid. Any help with direction to the links would be great.
9,727
Get the WSM and it will explain how to properly add shims to the pressure relief valve.
The vacuum is only used when you want to change just the filter and not the fluid.
wiltff
Aug 6, 2016
Milwaukee, WI
Thank you sir. I guess I should've looked in the WSM. My bad.
