Hydraulic Oil Change
ADAME2M
TRACTOR L245DT, TILLER L1020
Oct 21, 2013
CA
Can anyone help me? I'm going to change the Hydraulic Oil on my Kubota 245DT. I want to make sure how many drain Plugs to look for? how many gallons of oil does it take with a loader?
Thanks for any help.
farrelmh
L235
Dec 30, 2015
32
Palmyra,NY
24qts..if its 4wd / 23qts if 2wd if im incorrect , im sure someone will tell you ,
ADAME2M
Oct 21, 2013
CA
Thanks for the response.
Do you know if is the same 24 qt. if I have a front loader on it? and how many drain plugs?
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
678
288
Herald Calif.
Hello
You have 4 drain plugs and a filter.one drain plug on the transmission , one on the drop box ere the 4X4 shaft comes out.On the rear you have 2 more , one on each finial drive housing. They take a 14MM wrench.You also have a filter that is cleanable.It is located on the side of the rear end housing under the left hand step. You will see a small cover with 2 12MM head bolts. Remove cover and spring and pull filter out.
Good Luck Lance
ADAME2M
Oct 21, 2013
CA
Thanks for the help.
I new the transmission and the two on the drive housing. the fourth one is the one I needed confirmation the one on the 4x4 shaft. thanks again.
ADAME2M
Oct 21, 2013
CA
Can anyone tell me the size of the main drain plug socket?
ADAME2M
Oct 21, 2013
CA
Thank you!!!
That is going to save me a 4 hour round trip to go find out on my tractor. I was planning on changing the oil last week but didn't had the correct size, it was a lost trip. I will go this weekend to do the oil change.
vettdvr
Louisiana
I have a bx 1800 with loader and also do my gear oil. I have been using UDT fluid from dealer which is a 60 mile drive, Is there a substitute. I do don't want to risk damage but would like to have an option. Thanks not trying to hijack thread.
ADAME2M
Oct 21, 2013
CA
I use the Super Tech Hydraulic Oil from Walmart like Service Tech Vic advices on his video
