Hydraulic Mystery
J. McCaff
L2402Dt w/clam bucket, Bush Hog, Snow blower, Auger, 5' blade.
May 2, 2011
Lombardy Ontario Canada
Hi
I have a Kubota L2402DT (gray market), diesel 28 hp tractor w/loader.
Generally works great. That was until last week...started the tractor as per usual, went to raise the bucket..no lift. I tried the 3pt, no go. I gave the engine a shot of fuel and all hydraulics came to life.
All functions are run off one hydraulic pump.
Over the last 8 hrs of work the problem has repeated itself 3-4 times, sometimes right in the middle of a job.
This AM I can not lift the bucket or 3pt hitch.
I have slightly opened a fitting on one of the hoses to check for fluid flow, and yes it is moving, and appears to be under some preasure.
I have by-passed the front end loader, to check if 3pt works-no go.
I have traced the lines looking for an inline filter, before and after the main filter,(main filter changed a month ago), again no luck.
I have taken the pump out and dis-assembled...all looks really good. I could not see any signs of wear. When turned by hand it pumps fluid.
I'm stuck...maybe a hidden filter I can't see??
Any insight would be greatly appreciated.
Thanks
J
J. McCaff
May 2, 2011
1250 hr.
Just got service book in the mail today.
I'll take a look for the suction filter..is it in the transmission?
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
80
Pemberton NJ USA
You indicated that the main filter was changed a month ago and that your problem has developed within this last week, Is it possible you have used the wrong filter?
J. McCaff
May 2, 2011
It is possible the filter is wrong.
I purchased the machine used, not that long ago and the filter on it was a john deere filter.
Took it into Napa Auto parts and they matched up a filter that threaded on but was slightly smaller in size....not much but a little.
I never saw an original to compare it to.
Because of the month of running w/no problem, I didn't consider that.
Just received the parts book yesterday, I'll order a Kubota filter just to make sure
Thanks
J. McCaff
May 2, 2011
Hey meanjean.
Service book does not show any other filter for the hydraulics other than the one at the pump.
Emailed a dealer in Australia that actively sells the L2402DT, asked about hydraulic filters, they answered that that model only has the one filter, at the pump.
I think I'm going to be changing filters quite regularly.
Thanks for the input.
