Hydraulic lift issue on mower
yeltsin71
ZD28, B2850
Oct 6, 2024
New Zealand
Have a hydraulic issue on my ZD28 mower . At low revs and with deck lifted I don’t have enough hyd pressure for drive motors. If I increase revs or drop the deck down it works fine.
When I turn the motor off the deck drops on its own even with lift lever in up position . My working theory is a valve to the deck lift ram is not closing so using all pressure to keep deck up so not enough for drive motors at low revs.
Any feedback on this theory and if so which valve it might be?
9,749
Go over the WSM, it should cover the hydraulic system pretty well.
