vic , i moved my loader lines and tapped in to the high pressure line per your video . after i did this i noticed the loader seemed to have more power but also was more of a drain on horse power when in operation .also the toggles for the loader wanted to stick in the wide open position when operating and cause the motor to bog down to the point of shutting off . today as i was moving some dirt the hydraulics stopped working altogether . neither the loader or the 3 point will respond . if i try to raise the bucket it drops lower . they will hold their position and dont leak down but will not go up . i unhooked a steering line to see if fluid was coming through . it was but looked like water coming out of a water hose , there seemed to be no pressure . i removed the rear cover on the suction screen and to my surprise there was no screen inside . there is a filter on the right side of my tractor that you get to by removing the bottom plate , this filter looked relatively clean but i cleaned it and put it back anyway . the fluid that i drained was really brown looking . have i got a bad pump and do i need to put that rear suction screen in since i have the one in the front ?
