Hydraulic cylinders and hydraulic coupler LA435
Randy K
BX1860, G2160
Jan 10, 2016
26
Fond du Lac, WI USA
For Sale: 2 loader lift cylinders, 2 loader bucket cylinders & coupler assemble from a LA435 loader. Could be used for other uses. Lift I believe are 7J065-63010 or 7J065-63110, bucket I believe are 7J065-64010 or 7J065-64110. Both have pin holes are 1” diameter, center on center-extended length 36 1/4” retracted 22 1/2” rod dia is 1” tube OD is 2 3/32” guessing 1 3/4” piston. Some 90’ hydr fittings for hose to cylinder are missing. 2 have 90’ grease zerk on rod, 90’ grease zerk on dead end. Other 2 have straight grease zerk on dead end, no zerk on rod end. Loader side hydraulic quick coupler w/4 hoses. I believe coupler is 7J065-85020. 6 cylinder pins. Cylinders are $100 each, loader side hydraulic quick coupler $125. As is, cash only. Any questions, PM me, I will get back to you, I am in WIS.
