Hydraulic Control Valve Kit B2056-1 Needed
Ted Caveglia
Kubota B7400 HSD
Jul 29, 2022
Butler, PA
I ordered this kit a few months ago and am told it is on back order with no estimated delivery date. I need it for a snowblower being mounted on my 7400 HSD. Does anyone know where I could get one of these kits? Thanks
11,057
You're trying to get a kit that was very limited production to start, and with the tractor being 10+ years out of production probably isn't high on the list.
You don't need that kit to make it work if your willing or able to do a little of your own work.
Get a 4 position open center loader valve and some hoses.
You'll have to make the mount for it.
Surplus supply for the valve and get the power beyond sleeve.
Discount hose for the rest of the parts.
Ted Caveglia
Kubota B7400 HSD
Jul 29, 2022
Butler, PA
Thanks for the suggestion. I will take a look at this option.
Ted Caveglia
Kubota B7400 HSD
Jul 29, 2022
Butler, PA
You will also need a hydraulic outlet block - that is not off the shelf. Do you have a loader on the tractor?
Herein lies the problem. I do not have a loader. There is an outlet on the tractor that (I assume) the Hydraulic valve kit attaches to. I don't have a clue how I would attach a third party valve to this. Someone suggested a hydraulic pump that runs off of the rear PTO but I would only use this option as a last resort.
7,259
Its not a huge problem. All you need is a replacement for the blanking plate with two ports for the valve. Easy to make - PM me.
7,259
Actually no need to PM me - the OEM outlet block is still readily available from Kubota. Messicks wants $28 and website says they have 3 in stock.
Then all you need is a valve - I would recommend this one both for price ($125 with the optional power beyond sleeve) and availability - (ships for free in 1-2 days).
I am going to guess thats considerably less than the unobtanium OEM kit. Picture below shows how you plumb the connections to the tractor.
