Hydraulic Chute Deflector for a BX2750
Mrfreon2u
BX22 w/54"MMM, Bagger, & snowblower
Nov 21, 2011
Rehoboth, MA
Hello everyone,
I have a 2001 BX22(since new) and just recently purchased a BX2750A for it locally. I was able to recondition the blower and install the unit with the thanks for all the posts I read on this site. I would like to add a hydraulic chute defrector to the FEL control if its possible. I've seen some posts of other members able to accomplish this task, I was wondering if the dump positions of the loader valve could be used. Any infomation or pics would be appriciated.
Ancbill
Bx2360, 54" mmm, BX2750D snowblower, RB0560 rear blade, psycho border collie
Dec 17, 2011
49
Anchorage, ak
I plan on doing the same thing. I'll get the surplus center hyd motor number 9-7907, a coupling, fittings and hoses of course. I've read that the right position has two spots, to get the chute to rotate to the right you will need to move the joystick into the second detent position on the right.
Mrfreon2u
Nov 21, 2011
Rehoboth, MA
Ancbill:
Were you planning on using hydraullics for rotation or chute deflection? I'm planning on using the manual crank for rotation for this winter (so snow yet), but will work on the deflection of the snow chute with a piston and some custome brackets for an old oil barrel I remove from a job recently. I'll be drawing up some templates and seeing if it will work. I'll be posting my progress as I go.
Ancbill
Dec 17, 2011
49
Anchorage, ak
Sorry, I miss read your post. I've been thinking about the chute rotation so much, I figured everyone else was too!
I plan on sticking with the current design for the deflector. Good luck with your design.
