Hydraulic Auger / Mixer Project
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
The content of this post has been edited to remove any possible offensive material. Sorry for the post.
If you would like information on this mod, send me a PM, I will be glad to provide it.
BX23-S,57 A-C D-14,
6,087
Nice 'little' project to keep you busy. I usually 'prefab' everything out of wood. Easier to recut/drill holes/etc. that way the steel fab process is quick and accurate.
Does the tractor have enough GPM/pressure for the motor ?
As for the drum, there's a free 'cone layout' program on the web, somewhere. I've used it to make templates and smaller 'models' of things, like dust collectors......save a lot of 'four letter words in the air'........
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
Thank an offended member.
3,928
I wish my welds looked as good as yours! I have a hard time seeing the difference between the blinding light and the puddle and usually put too much metal down and/or not enough heat or too much.
Wood you be able to give better welding advice?
(Playing the joke with you, as you wood know.) :p
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
120
105
Lopez Island, WA
A few things that help:
1. If you need reading glasses, wear them. Progressives lenses don't work very well at all because moving your head to see with the right part of the lens is a PITA. If you're welding stick, use a fan to blow the fumes away.
2. Rig a cheap halogen worklight to add more light. Use a soapstone to mark seams if you're having trouble seeing.
3. Prep butt seams by grinding a V, then fill the V.
- Bart
4,780
If your joke was the wood,,, not much of a joke lots of people use a wood mock up before they start to glue steel together
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
581
588
Lake Almanor, Ca
That is slick...I like it. I assume that mixer is attached enough to use the loader to tilt and dump the mixed concrete?
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
hope to float
L3450
Feb 18, 2018
490
61
Ireland
Would it take much to make a kinda stepped cam to fit into a sleeve so that you could make a post driver. you would of course need another swivel ;)
3,928
I want to get in-line for Serial Number TWO! ;)
BX23-S,57 A-C D-14,
6,087
it's too pretty...best loan it out to a 'friend' who'll leave 1/3 of the concrete in it overnight.........:mad:
yeah, when I wanted to borrow a 1/3yd tow behind unit from a friend, HIS friend(1st guy to borrow it..) did the dirty deed...
I NEEDED it, so I spent 1/2 day chipping crete out and repairing the drum....
after that my friend NEVER loaned nothing to nobody, cept me.....:D
you should post a 'parts list' for other who want to make one.
