Hyd Top Link M9540
russell.still.5
197
Lafayette, Alabama
I used a Grizzly Cat 1 top link from Agri Supply on mine. I’m not sure of the size. It’s just the cylinder. It’s cheap route if that’s what your lookin for. You have to supply your own fittings. You will need a flow restriction fittings as well. Got mine from Ken’s.
http://www.boltonhooks.com/hydraulics.html
I would go with Fit Rite if i had to do it over again.
https://www.fitritehydraulics.com/
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Not looking for low cost, want good quality. From postings Fit Rite has a good following so they would be a good choice, but currently have a 20 week lead time. Been doing some other reading and found Hay Tools which also have good write ups.
Need to get an implement to determine how long it needs to be. Fite Rite said 3" cyl and 23.25 to 35.25 stroke. Hay tools list 3" cyl and 24 to 35 stroke and check valve, also others, but also don't know their lead time
http://www.haytools.com/TNT.htm
MtnViewRanch
719
176
Lakeside Ca.
Thanks, some people feel that the wait is worth it, many do not and I understand that. ;)
MtnViewRanch
719
176
Lakeside Ca.
The 70mm is a 2 3/4" dia cylinder. If he has it in stock, that unit will work for you, don't forget to get the reducer bushing for the tractor end. ;)
