HST pedal problems
olekid
B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow
Apr 9, 2013
95
Mount Uniacke, Nova Scotia
Greetings, have a B7510 HST, the hst pedal sometimes doe not return to neutral and I have to reach down and move it a little in order for it to start, any suggestions to fix it?
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
Look to be sure no trash such as limb or twig is interfering with it. Under the floor board. Lube all pivot points.
5,506
2,215
yes. do as Palmettokat suggested.
If you do that and it still sticks remove the dampener from the linkage and see if it still sticks. if no, replace the dampener. If it does still stick, you're probably going to have to replace the neutral roller, and that is not a particularly "fun" job.
Bpaw
owensboro ky
My neutral roller is shot and I just try to keep grease on it and it helps until I can fix the roller but looks like a heck of a job.
