Inherited 84 inch landpride side discharge mower. Too big for my b9200. I an thinking of getting larger tractor. What would the minimum hp needed to reasonably power this mower?
I have a Landpride 72" FD72 side discharge.I bought it new in 1990 for $2,300.
I find that unless the land is very flat it does not cut well as the width means it does not follow the contour of the ground.
My suggestion, before buying a tractor based upon this mower, you arrange to try the mower on a borrowed tractor to be certain it provides the cut you like.
Besides the power to run the mower you need to be certain the 3pt of the tractor you buy is strong enough to pick it up and still have the front wheels on the ground. They are heavy at over 600# and the weight is far back on the hitch which lifts the front end.
I would sell mine for $1,000 just to give you an idea of what yours is likely worth. It may make more sense to sell the mower and get a mower your tractor can handle which may be around 48".
Dave M7040
