Howling sound on start-up
Bidwell3
M5400 Tractor
Jul 23, 2021
Tucson, AZ
My M5200 sometimes puts out a loud howling sound after start-up. It goes away after 30 seconds or so, sometimes continues for a minute. Everything works fine for the rest of the day. Fluids are at the correct level. Any suggestions would be appreciated.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
524
289
Mandeville Louisiana
I'd suggest checking the alternator belt tension and inspect the belt, pending run hours the belt could be loose and becoming glazed
Motion
Aug 17, 2020
524
289
If the belt is the problem, remove it and spin both the water pump and alternator, when replacing the belt clean the belt and pulleys thoroughly with denatured alcohol. Also good practice would be to buy a new belt and use the old one for a spare.
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
54
North CA
Just wondering. Does the M5200 have a radiator fan clutch?
JohnDB
M4500DT
Jun 9, 2018
376
NZ
My M5200 sometimes puts out a loud howling sound after start-up. It goes away after 30 seconds or so, sometimes continues for a minute. ... Any suggestions would be appreciated.
Feral tractor? Full moon at the time?
