How to remove the cutting height control dial
jetcat21
Milford NH
I have a Kubota BX1800. I need to remove the floor boards so how do you remove the cutting height control dial to be able to remove the floor board. The only thing keeping me from removing the floor boards after I unscrewed all the nuts and bolts is the dial. Thanks
jetcat21
Milford NH
It's not threaded onto the shaft it appears to be pressed onto the shaft. However when I try to pull it off it doesn't budge. What is the best way to try to pop it off without breaking it? Thanks.
Mr. K
Administrator
522
139
www.orangetractortalks.com
Hey there again - Vic is your best bet for an answer on this one. He's out in the shop during the day (earning his keep) but he typically shows up in the evenings to answer questions and give advice. Hang in there! :D
