H haljam New member Mar 16, 2012 5 0 1 Salado, Texas Dec 26, 2023 #1 Need to remove power steering cylinder on my L2900 to replace seals. What is required?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,386 8,700 113 Sandpoint, ID Dec 26, 2023 #2 Just remove the pin, a couple of lines, and a couple bolts. Do some research as there were some cylinders that had a bigger issue than the seals. Reactions: 1 users
H haljam New member Mar 16, 2012 5 0 1 Salado, Texas Dec 27, 2023 #3 Thanks. What is the pin you referenced?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 33,386 8,700 113 Sandpoint, ID Dec 27, 2023 #4 #150 is the pin, it's held in place by 2 bolts on the keeper #170
H haljam New member Mar 16, 2012 5 0 1 Salado, Texas Dec 27, 2023 #5 Thanks. What tool is required to remove the circular clip at the end of the cylinder to open it?
H haljam New member Mar 16, 2012 5 0 1 Salado, Texas Dec 27, 2023 #6 haljam said: Thanks. What tool is required to remove the circular clip at the end of the cylinder to open it? Click to expand...
