Bought a M900 new, from day one ac was poor. Cool at best and not much of that. I use this tractor for baleing and spraying, it is well taken care of, doesn't sit outside unless necessary in field, oil changed every 100 hrs etc.These are the things I did along the way until I finally fixed the AC.
Blow out condenser EVERY time its used. If you don't have a Radiator Genie get one 35$ well spent!!
Replaced AC compressor,just to do it.
Replaced Expansion valve
Removed heater core so fan wouldn't have to push thru it.
Lined cab with heat barrier
Wrapped exp valve with insulation
Added 600 cfm electric fan to blow on stock ac condenser
Relocated battery out of front area to tool box location.Now air is drawn from underneath,sides and front area. Tractor should have been 4 in longer,big difference in ride and room to work.
BUT what really worked was adding a 2nd ac condenser,WOW what a difference! AC is now 38 degrees.
The 2nd unit is 14x15 inches. Cost was $80 for condenser, $55 for ac line ad fittings,$150 for ac crimping tool(probably could have borrowed but this was cheap experiment anyway). Now it cools like a 30 year old JD,Allis Chalmers or IH,like it should have!! http://www.orangetractortalks.com/forums/attachment.php?attachmentid=12807&stc=1&d=1410402632
