how to check voltage of starter/generator
joezzz
B6100
Jan 3, 2013
essex, CT
I have a B6100 tractor 1983 and want to check the voltage output without taking the unit out and placing it on a test stand.
Any suggestions as to how to do that?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,050
Williamstown Ontario Canada
If you have a multi meter, checks are simple.
To check dynamo ( which rarely fails) disconnect its two output leads which are usually blue.
Measure AC voltage between the two blue leads Expect to see around 30 volts,
With system totally connected, measure battery voltage with engine at max rpm. This time you are measuring DC voltage and expect to see 13.8 to 14.2.
Dave
2,897
Ditto to what Dave said - measure AC at the wires - and DC at the Battery.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
Dave
Measure Dynamo AC voltage at full throttle.
