How often to change oil in Rotary cutter?
thedevilyoulove
L3901 HST with LA525 FEL, Land Pride RCF2572, pallet forks, 3 pt carry all
Jan 27, 2016
143
Woodbine, Maryland
I have a land pride RCF2072 that I purchased new last May. I've had it about a year now. Should I change the oil in the gear box? The manual says to use EP 85-90w but doesn't say how often to change it. Also, I don't see a drain plug anywhere on the gear box. Do you all change your gear box oil in your rotary cutters?
WFM
L3800
Apr 5, 2013
1,199
506
Porter Maine
I have a LandPride RCR1860 bush hog.....its three yrs old now. And I haven't changed to oil yet. My owners manual says 80-90W EP gear oil. But as with yours gives no recommended time when to change. Just add if its low.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
I have several bush hogs, of varying age and manufacture... I've never changed the oil, unless a bad seal did it for me. Unless it were burnt smelling, I'd keep it full, and lever B...:D:D
