How Much Clearance Inside SSQA Adaptor?
Mr Haney
L3710, ZD326S
May 23, 2022
318
81
FL
I'm just about done converting my Kubota LA681 bucket to SSQA. I cut the mount plate I bought, and I'm installing in in two pieces; one on each end of the bucket.
How much clearance do I need between the outsides of the SSQA adaptor and the insides of the mount plates? I assume they don't have to be in contact, since that would make changing attachments very difficult. I am thinking of leaving 1/4" of space between the adaptor and the insides of the plates when installed.
Mr Haney
L3710, ZD326S
May 23, 2022
318
81
FL
I cut it to make it easy to install. I got it from Titan.
In case anyone else is wondering, the answer is that a standard SSQA plate measures 45" from side to side, from the inside of each wall to the other.
mikester
M59 TLB
Oct 21, 2017
3,882
2,530
www.divergentstuff.ca
You want enough clearance so it isn't a pain to hook up. There are some dimensions poster under this thread
