C clark_bailey Member Equipment Kubota L3710, L3600 and Bobcat T190 Mar 19, 2010 170 0 16 West Alabama Sep 16, 2016 #1 How to bench test s glow plug? What ohm is correct? If 12v and ground applied what should happen? (besides getting real hot if it's working?)
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,013 2,871 113 Bedford - VA Sep 16, 2016 #2 clark_bailey said: How to bench test s glow plug? What ohm is correct? If 12v and ground applied what should happen? (besides getting real hot if it's working?) Click to expand... Pure ohms test should be less than 10 ohms - actually closer to 1-2 ohms. And getting real hot is a good way to know! You dont have to hook it all long to see or feel if working. Infrared probe will tell you quickly!
C clark_bailey Member Equipment Kubota L3710, L3600 and Bobcat T190 Mar 19, 2010 170 0 16 West Alabama Sep 25, 2016 #3 tested them all while out of the block, 0.9 ohm, put them back in and they were all between 0.9-1.0. thanks for the helpful info. Sent from my iPad using Tapatalk
