Ok… get your mind out of the gutter!
Leading title I know, but a serious question. I’m running through ideas for a lite-weight, easily-removable belly pan/skid plate for my L4802. As I lay under the tractor mulling options I notice this little dangling appendage from the bottom of the clutch housing. I looked in the manual and it’s the split pin that you push up to see if water has built up in the clutch housing. Well there is no way this tiny wire survives its first encounter with a grape vine. I can’t see it lasting long in tall weeds!
is it important? What do you do when it bends or breaks off?
