How critical is valve reccesing
Dre
sydney Australia
I have a b7200 with a d950. I bought it not working and am doing a head job. How critical is the valve recession the manual says 1.3 mm all the intake valves are at 1.6 mm and the seats need refacing. Do I need new valves.
8,893
Honestly, critical to a point, as the valves set deeper in the head the compression goes down.
If they do go too far in the compression ratio drops too much and it will make it harder to start and give you less power.
CountryBumkin
Sep 27, 2015
568
Central FL
If the drop in compression is a concern, you could mill a few thousands off the head and restore the compression.
8,893
Yes you could, but because of the way that the pre-chambers are set up it's not a good idea to remove that much material off the head. ;)
Knott
2015 BX2670-1, BX2755HD Snow Blower, Farmking 4' box Blade, BX 2760A Plow Blade
Jun 2, 2015
101
Manitoba
It all depends on your assembled height measurement. I would grind the valves & seats as needed & measure to see if it is still within acceptable tolerances. If it is then finish assemble & if not I would replace the seats & valves. This is just what I would do.
Dre
sydney Australia
Thanks guys. I will be grinding the valve seats next week. The valve seats on a d950 are non replaceable and the manual says replace valve and if it still not within spec regrind or replace head. But is it correct in thinking that the only issue with excessive recession is a slight drop in compression.
1970cs
1,124
Grand Ledge
NIW has it right! The change in compression ( lower), will effect the cold starts.
When is was in my dealerships shop I did most of the head work. Some for walk-ins, but mostly during engine rebuilds.
Pat
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Dre, I have never meet a cylinder head that could not have valve seats replaced or pockets cut in the case of heads with parent metal sealing surface. Is this the case with your B7200?
If you have a good diesel machine shop in the area go talk to them. Some where there is a kit or seat that can be installed in you head. Get the recession correct, it has a significant impact to compression ratio. Jeff
