hose help
SwampCat
B7510 HSD
Jun 7, 2015
72
Northern,Wi. U.S.A.
Need hose for FEL LA272. The part #s are 75532-66630 / 75536-66620 / 75532-66610. Local dealer does not stock them. Would anyone know the SIZE & fitting type ? I can measure legnth. Just want to make sure when I call the hose place I have the correct info to tell them so I get the right ones. Yes I will take the old one in to match up, but want to call first to get some idea on $$. Thanks for any and all help. SwampCat.
mrmr56
G4200, Z482, 3 G5200's
Jul 22, 2015
Waco, TX
All 3 of the hoses from the online suppliers like Coleman's would be about $95.00 for all 3 hoses. Most local hose shops will have a better quality hose and a slightly lower price. (in most instances, depending on how greedy the owner is) As the retired owner of a hydraulic hose shop, I found that once the first hose went, the others went in rapid succession so you ended up on a first name basis with the customer until they were all replaced. I would take a sample and get a quote to compare.
Tooljunkie
May 13, 2014
4,150
27
Best to take hose with you.most hydraulic shops have every fitting you could imagine. Most cases the hose is superior to oe part.
4,544
The key for getting good prices on hydraulic hoses is to find an actual hydraulic hose company. ;) We were using a company in town till the oil field tanked and they closed there doors. Hoses that were costing me between 30$ and $50 are now costing 100$ plus with having to use Napa. Plus anything odd ball has a minimum 3 to 5 day turn around as well. I miss McCarty's :(
