Highest a b7100 belly mower can mow?
dale5150
b7100hst
Jan 11, 2023
How can I adjust the lift height of my 60in mower on my b7100? This is all new to me. I will be using it on my back field and I want it high as to not run over the turtles that live here. I was told i coild change the rear armature somehow to make it raise it more. Thanks!
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,128
933
Williamstown Ontario Canada
Go to Kubotabooks.com by following this link.
RC60-71B
Your tractor uses a RC60-71B mid mower. Look for the Operators' manual for your mower which will have the instructions you need.
Dave
dale5150
b7100hst
Jan 11, 2023
I will look at that. I also need to know what to do to keep it fron dragging when I am grading.
Donystoy
Dec 10, 2013
504
165
Binbrook, Ontario
Your lifting arms are the same as what is on the mmm that I had on the b7200. Max height would be had when the mower is raised to maximum height and wheels are off the ground. Lifting arms can be adjusted until the mower is hitting bottom of tractor when in the raised position. I understand your concern for turtles as I am also constantly watching for them. I hit one in tall grass when Bush hogging a few years back.
