HI guys new to site
3/D archery
Kubota bx25dlb
Aug 1, 2021
LI NY
Issue need to know where to get replacement tank fitting which fuel hoses connect to
For bx25. Pulled tank fuel sensor rusted out ,changed it. Cleaned out tank , then removed fitting all four had rust in them .
Besides finding out where to get fittings , what is a good fuel additive for condensation ?
Spoke to Messicks in PA , they said part not listed ,they called Kubota ,was told they are part of buying a new tank , for $224 dollars
Which I truly find to be BS . Thanks for any help
WAS BANNED FOR NSFW PICS
5,164
Take the old part to a machine shop and get an estimate as to the cost of having an new one made. I would consider brass or stainless steel for the replacement to avoid the rust issue in the future.
I use Power Service diesel fuel Supplement for years now, and have never had a fuel problem. I buy a gallon at a time, and just "estimate" how much I need for the tank of fuel. I am probably overdosing the fuel, but it causes no harm, and have never had a fuel issue in over 15 years. I also have dedicated fuel containers, and I never completely empty them to the bottom. When I get down to a few ounces at the bottom of the container, I pour that into a glass jug, and let it sit overnight. If there is any moisture in the fuel, it will settle out and show up as water at the bottom of the jug. If I find water in the fuel, I put some Power Service Diesel 911 to help eliminate the moisture. I have a BX tractor, so there is no water trap, and I have never had a need for one. If I had a bigger machine, or a problem, I would add one to the tractor, but so far, I have been very lucky without one.
whitetiger
Nov 20, 2011
3,840
2,232
Kansas City, KS
Scag mowers uses the same fitting and grommet in their hydrostat oil and fuel tanks on most models of zero turn ad stand on units.
JerryMT
Jun 17, 2017
529
154
The Palouse - North Idaho
Some of the fuel additives cause water condensate to "slide off" the fuel filter and drop to the bottom of the filter housing where they can be drained out. There is a management practice that is quite simple and, while nothing eliminates condensation, it can be minimized. Try to keep your tank as near to full as you can, especially when the tractor is not used for long periods of time. This reduces the ullage so less air, with attendant moisture, enters the tank due to normal barometric pressure changes.
armylifer
Mar 26, 2013
2,343
1,092
Thurston County, WA
I use acetone to keep my fuel dry. I put 1 ounce of acetone per 5-7 gallons of diesel in the spring-summer and 1 ounce acetone per 3-5 gallons of diesel in the fall-winter.
