Help - ZB6001 - Kubota Equivalent
dunk
ZB6001
Sep 21, 2009
Aberdeen, Scotland
Hi, I am new to this site. I hope someone can help me to find out about my Zen-Noh ZB6001. This is a fantastic tractor and does all I need it too, however parts are the problem. My questions are as follows: what is the Kubota equivalent, what Hp does it produce and how old is it? The number printed on the side is B6001-25805 and it has a 3 cylinder engine. Thank you .
TopGear
68
Australia
Hi dunk
Your B6001 will be pretty similar to a B6100 (non gray market). Check out the following links for operation manual
http://www.kubotabooks.com/AutoInde...s/&AutoIndex=6e3f4a6671cf0246fe27be1f41be9dea
and you should find a parts manual here
http://www.kubotabooks.com/AutoIndex/index.php?dir=Tractor Parts Manuals/
Nearly everything is identical. A funny thing is that if you buy the workshop manual for the B5100, B6100 and B7100 (non gray market) version the actual photos in the manual are of a B6001!
Anyway hope this helps.
Cheers John
dunk
ZB6001
Sep 21, 2009
Aberdeen, Scotland
Many thanks John. I will look at the links you gave. I plan to give it a full overhaul in the winter, so I am sure I will have more questions. Thank you again.
Duncan
