I’ve recently acquired a G1900 ride on mower and the PTO only stays engaged if you hold the lever down. When you take your hand off is disengages and the lever moves back. After spending many hours trying to solve the problem I’ve noticed:
1-the PTO return spring appears to be missing
2-the belt retaining screw is missing although I don’t think this is causing the issue
3- the PTO lever doesn’t appear to be able to move forward as far as others I’ve watched on YouTube. The lever makes contact with the metal inside when it’s in a near vertical position.
The photos illustrate the above.
It would be great to get this resolved and any advice is greatly appreciated!
Thanks
Thanks
