I hope nobody minds if I sorta re-post this. I added the info to an older thread but wondering if it didn't get noticed that way.
L3301 tractor. Only a year old, but stored under a lean-to where rodents got to a few wires last winter.
The fuel gauge does not read fuel level. It jumps to 100% momentarily when starting the tractor, like the other gauges, so the gauge itself isn't completely dead.
There's a tiny bit of rodent damage about a quarter inch behind the plug that connects to the tang on the fuel sensor. I checked for continuity from the plug to the Y/G wire at the back plug of the instrument panel. The wire's still good.
I turned the tractor keyswitch to "on" and tapped the fuel sensor signal wire to the fuel sensor ground wire, expecting to see the gauge jump, but it didn't move.
The fuel sensor is out of the fuel tank. It's rusty as heck and doesn't seem to respond to movement of the float at all. I get a couple of ohms at all positions.
Does anybody have some advice? The fuel sensor seems to be kaput, but I should be able to fake a signal to the gauge and see it move. I don't know how to do that.
