Help! Old Equipment spec's
WPA245
1979 L245DT;model1200loader/K650backhoe
Aug 7, 2015
14
Greensburg, PA
Anybody have spec's or a source for info. on the old 1200 FEL or L650 backhoe? Nothing on Kubota's site. In particular I need the weight of these attachments.
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I have a manual for the 1200 loader and could not find a weight spec. I believe the K650 is a fairly small backhoe with the telescopic stabilizers? I have a Kubota/Woods backhoe of slightly larger size and no weight spec in that manual either. My 1200 loader will pick up my backhoe/subframe if that helps any.
Neither is too heavy, how accurate of a number are you looking for?
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Take a guess?
Maybe you can guess size for size
Kubota BT602 off a BX25D
Weight:617 lbs
3,336
Could not find any FEL weights.
Not familiar with your hoe, but my B670 has a dry shipping weight of 710lbs, plus the weight of the bucket:
9" 33lbs
13" 38lbs
16" 43lbs
Maybe you can extrapolate.
WPA245
Aug 7, 2015
14
Greensburg, PA
Thanks for all the responses.
As long as I'm over weight and not under I'll be OK. I'm trying to size a trailer to haul my tractor and a both attachments. It would be nice to get owners manuals for the attachments eventually.
Thanks Much for the help.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
... It would be nice to get owners manuals for the attachments eventually.....
will caveat 100TD's point with a step saver on manuals. Se the first link in this very helpfull thread
http://www.orangetractortalks.com/forums/showthread.php?t=20495
There is a similar thread in every forum here full of links to great info; particularly to anything you can imagine that has been asked about over and over and over (what tires, what lube, What hydraulic fluid, where can I get manuals, how do I fix xxx, etc etc etc). It is a great place to start. Followed by searching as 100TD suggest
LRestivo
Yanmar YM155d with YFL 155 FEL & YBH 600 backhoe
Nov 7, 2015
Hubbard,Oh
I think this may help.
I have a Yanmar YBH600 backhoe that is most likely the same unit. It is 650 lbs. minus the bucket. Look at the dealer brochure and price list I've uploaded from 1981. Not sure yet but from the little research I've done so far, I think Brantley might have built them. I'm still looking for more info on that.
