Help - No Drive Issue after Maintenance
F3060K
F360 Kubota
Oct 30, 2021
QLD
Hi I purchased this preowned mower & just performed the following but now it won’t engage to drive forward or backward. Any help would be greatly appreciated as I’m new to this type of mower.
1. Replaced pivot seal in rear axle
2. Drained out all old transmission fluid and replaced with similar as previously used (following books specifications)
tinkerwitheverything
bx2370-1
Jun 3, 2015
318
72
Manitoba
It’s a Kubota F 3060 front cutting from 97 to 2005
I'm just going to throw this out there. Did you buy Kubota oil filter and oil. Not sure why it shouldn't drive if it was working before you changed the oils etc. Did it drive before you changed oil etc: You say you just bought it so I'm wondering if it was a issue before you. I know of one person who the driveshaft from the motor to the hydralics had failed. So can you maybe check to make sure the motor is actually driving the hydralic system etc:
Mlarv
BX23S
Jan 19, 2020
218
176
Crossville TN
Check to make sure your HST is in Fast or Slow along with 4wd (if equipped) is in gear. If it is like the BX2380 HST you should have a Turtle and a Rabbit. It has to be in one or the other not in-between.
