RCK60P-21Z Gearbox..
Removed the gearbox due to oil leaking from the output shaft seal. Once on the bench, noticed the shaft had 1/8" in/out movement in the seal. With shaft removed, gear is secured in the bearing and assembly moves the 1/8" on the shaft. If this is normal, shaft "floats" that 1/8" in the seal??
Pics attached..
Thanks in advance !
Pics attached..
Thanks in advance !
