I just bought this BX-2370 with a FEL. It has 70 Hours. Used, but may be under warranty. I used the tractor for six hours yesterday with no problems. I fired it up this morning and used if for about an hour and the Hydro drive would barely move the tractor. Pulled it in the garage......pulled the hydro fluid dipstick.....Foam...Bubbles.
The FEL and rear 3pt lift work okay but when I drive it, it will move okay at first, then get weaker and weaker until it hardly moves.
Fluid level is correct. Foam is not.
Should I go ahead and change the hydraulic fluid and clean the filter? Or do I have something else going on here......Thanks.
