K kosborn82 New member Equipment mx 6000 rops Jun 15, 2020 2 0 1 fairdealing, mo Jun 15, 2020 #1 where do i find the headlight relay on my 2000 MX 6000 rops? had power hooked to trailer plug working but power stopped, lights and turn signal inop now and have code of E-21. fuse is still good but no power to fuse clips for lights in fuse box.
SidecarFlip Banned Equipment M9000HDCC3, M9000HD, Kubota GS850 Sidekick Oct 28, 2018 7,182 563 83 USA Jun 15, 2020 #2 On my M's there isn't one. Headlight control is directly through the Multifunction switch with the positive lead fused through the fuse panel. Yours could be different. I suggest the schematic in the Kubota WSM for your model.
K kosborn82 New member Equipment mx 6000 rops Jun 15, 2020 2 0 1 fairdealing, mo Jun 15, 2020 #3 thanks i'll see if i can get a hold of those
Dave_eng Well-known member Lifetime Member Equipment M7040, Nuffield 465 Oct 6, 2012 5,257 1,050 113 Williamstown Ontario Canada Jun 15, 2020 #4 You may find you have to lift the instrument panel to get at the relays. This is from looking at a different MX tractor WSM. Often, since your tractor utilizes halogen dual filament headlight bulbs there would be a relay for high beam and another for low beam. A relay failure would be rare. Dave
