Headlight Lens
johncrumbie
9
Covington, GA
Broke a lens when limb wedged up with FEL. B2601. Can I replace lens only. Where can I get it.
Kubota/Messicks only offer full panel for replacement. Around $235.
SDT
Apr 15, 2018
3,601
1,338
Don't think so.
Believe that headlamps are serviced only as assemblies.
SDT
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
238
88
S.E. TN
Thats not it. I poked a hole in one of mine, and found out it’s around $250 for the whole assy. Can’t buy just the headlight lens. I had a scrap headlight lens I had layin around and cut out a piece and glued it over the hole. cant really notice it cept up close.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
The lens is not serviced separately. If the housing is ok, make one from plexiglass. You can put the curve in it with a heat gun. I did this on my Honda 4518 about 5 years ago and it's still intact.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
Would Lexan work as well? Understand it is tougher.
