I have a 2010 7040 cab model with 4 wheel drive with 383 hours on it. The tractor started to idle rough and then if finally died like it ran out of fuel. I went ahead and changed out the fuel filter (400 HR maint) and cleaned the water separator, bled the system as the repair manual states.
Now the darn thing will start but dies like it is out of fuel. I bleed the system again and after multiple tries it will start and run like a top for hours but if I shut it down and let it sit it will do the same thing.
I have disconnected all the fuel lines and blew them out, bled the system again and it is still doing the same thing when I try to start it.... I ran it yesterday for over an hour dragging some pastures but today it did the same thing. I have noticed that when the tractor is running the fuel level in the water separator bowl varies and does not stay at a level amount?? Never seen that before....
I have two Kubota's using the same fuel out of my bulk tank, the other tractor runs fine so I don't think its the fuel. I keep additives in the bulk tank as well as the tanks on the tractors.
Anybody have any ideas???? Winter is coming on and I sure don't need to be bleeding the system every time I try to start it.....
