HAMs SDR
3,867
Anybody playing with an SDR dongle? I dont know much about them so info other than youtube. Which can be a bit confusing when they speak for others that already know about a subject.
So which one and why, antennas, home brewed or factory Dipole, software down loads, problems, good things and not so good things,,,,,, OK GUYS Im 10-7 and standing by
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
No help here but thank you for the post. I've not been keeping up and had not heard of such a thing. Now I see another toy in my future. As far as antennas I suspect it will work with any receiving antenna you care to connect to it. I don't know impedance but I saw one picture with what appeared to be an F type connector as used in CATV.
5,574
Takes all the fun out of burning fingers and getting burned by vacuum tubes......
I did the dits and dahs, still have my dad's bug.
mikester
M59 TLB
Oct 21, 2017
3,813
2,431
www.divergentstuff.ca
I'm interested in using SDR for listening in to cheap wireless sensors ie. driveway alarms, weather stations etc and logging the data. This link has some interesting links to low cost SDR links in case you want to start off small before going all in on a system.
RBsingl
Jul 1, 2022
443
497
Central IL
The little cheap SDR dongles are fun to play with but if you are looking for even a "semi-serious" wideband receiver, they aren't for you. The lack of front end filtering combined with the limited bit depth will quickly get you into overload and spurious response issues. To get out of the toy class, you have to move up the more expensive SDR packages.
Being a vintage gear type, I went the other direction although I do have a SDR based high end Yaesu transceiver.
Rodger
armylifer
Mar 26, 2013
2,125
897
Thurston County, WA
Okay, this may be just a little off your intended request for information but here is a link to a web based sdr. You can try listening to some of the stations in different bands and see if there is anything interesting going on that you want to be a part of.
