T TinCanMan New member Equipment 1984 L3750DTS Tractor & BF900 Front loader Jun 3, 2019 9 0 0 81 Hawkins,Texas Jun 28, 2019 #1 When replacing the front wheel propeller drive shaft and couplings on an L3750 should grease be applied to the splines or should they be assembled dry? Last edited: Jun 28, 2019
R RCW Well-known member Lifetime Member Equipment BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU Apr 28, 2013 10,183 7,075 113 Chenango County, NY Jun 28, 2019 #2 I would grease it. I equate it to any other splined shaft connection....a little lube is a good thing. You're not going to take it apart again, so best to give everything a little bit of slickness. Sent from my QTASUN1 using Tapatalk
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,216 9,400 113 Sandpoint, ID Jun 28, 2019 #3 Yep a little grease will help with wear and moisture intrusion issues.
P PA452 Active member Equipment B2650 Nov 8, 2015 326 55 28 Western PA Jun 29, 2019 #4 I would definitely apply grease to reduce wear.
T TinCanMan New member Equipment 1984 L3750DTS Tractor & BF900 Front loader Jun 3, 2019 9 0 0 81 Hawkins,Texas Jun 29, 2019 #5 Thanks to all, grease it is.
