Grease zerk fitting getting stuck???
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
I finally broke down and purchased a 14.1 grease gun to prevent changing the tubes constantly. 319 reviews on Amazon 4.7 stars so I assume folks love it.
It pumps great but it keeps getting stuck on the zerk. And I mean stuck! In fact I pulled a zerk off my Jake's lift kit on the cart.
Am I doing something wrong? Never had this issue with the little grease gun. Watched videos about releasing pressure, but I don't want to take the thing apart every time I grease a zerk.
Tips? Tricks?
200mph
Mar 3, 2017
1,228
65
PA
Most couplings can be adjusted to alter the zerk hold-on force by rotating. Loosen the end slightly and see if that helps.
SidecarFlip
Banned
562
+1. Every coupler I've ever used, the front part will be knurled and you can loosen the knurled end to release the grip on the zerk I eave mine loose and if the fitting spews grease when greasing, tighten it a bit.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
That’s it. Thanks. With all the help I need not sure I should be driving a tractor :D:eek:
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
If you don't like adjusting the coupler, buy a "lock n lube" tip for your greese gun.
Sent from my LGMP260 using Tapatalk
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
On it! Just watched videos on them. Thanks for the heads up!
