Grease Gun
Stmar
B2650HSDC
May 23, 2017
948
58
Buffalo, Wyoming
A while back I bought a new grease gun, looked neat and was on sale so I picked it up even though I have a few. Never could get the darn thing to work good, it had plenty of tension the first few strokes then not much resistance so not pumping too much grease. I kept doing what was suggested to try and get the air out but nothing seemed to work. Finally took it apart and in the grease I found a small broken o-ring that looked like it went on the air purge button plunger, plus the end of the plunger was misshaped. Not being one to throw anything away I did an experiment, took the purge unit out removed the spring and cut off the plunger and filled the button fitting with JB Weld. The air purge button is optional since you can purge the air by losening the barrel the old fashion way. Don't know why but I get a kick out of taking something broken and making it work.
Stmar
B2650HSDC
May 23, 2017
948
58
Buffalo, Wyoming
It is a Lumax 1152, I picked it up at Home Depot. It was on sale, 20 buck range, and it looked like a decent gun. I will be interested in seeing how it works next time I grease.
armylifer
Mar 26, 2013
2,291
1,061
Thurston County, WA
In case anyone is interested I bought this one on Amazon last April. I am happy with it.
SidecarFlip
Banned
563
My hand guns all have clear polycarbonate barrels so I can see how much grease I have inside. Of course I don't use cartridge grease either. I bulk fill them from my air greaser. I despise grease cartridges, messy and a PITA.
Stmar
B2650HSDC
May 23, 2017
948
58
Buffalo, Wyoming
Good news, fix worked, plenty of pressure and squirts grease like it should. Put some new grease in, had a tube of marine laying around so put it in, blue color so I could see the results. All greased up and ready for winter, put chains and snow blade on since any other projects are halted. #1 diesel with a dose of White so it should take the sub zero. Keep telling the wife you don't have to shovel sunshine but now so many people are moving into Florida that the housing market is ridiculous.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I added a 1/8" street elbow on the outlet so that I can lay it flat against something making it easier for me to operate with one hand.
